fuel cut?
OnlyNeed4
56
Dec 17, 2003
port huron, Michigan
ok, i have a big 16g, apexi n1 dp and exhaust, dejon intake pipe, and k&n filter. i hooked up my manual boost controller the other night and took it for a test drive. i get to around 3k rpms in 2nd gear and go wot, it takes off fast until i hit 5k rpms where i think i have fuel cut. the car accelerated fine until it felt like hitting a brick wall and 5k rpms. im new to dsm's, so im not sure, but was that fuel cut, or was i running too rich or what. Some people around town that drive dsm's told me i hit fuel cut, i want to get bigger injectors and pump, but they told me i can over-ride fuel cut some how until i get the money for my parts. Is it possible to over-ride fuel cut? how do i do it? all comments are appreciated
Sounds like fuel cut... just turn your boost down to around 14-15psi until you get a fuel pump and injectors and an safc. There is a fuel cut defenser, but not many people use it. I believe HKS makes it.
i have the boost controller turned all the way down, to minimal boost. i make 9 psi and it hits fuel cut at 5k rpms and a bunch of black smoke shoots out the exhaust. no matter where i set the boost conroller, it still hits fuel cut at only 9 psi, i should be able to run atleast 12 psi shouldnt i?
did you hack your maf yet ?? if not hack away ;) that sounds like the problem and set the boost at 14-15 like herostar said... dont hack too much with no afc or fpr. your idle will suffer.
