fuel cut after 14b install
killer_eclipse
251
3
Aug 10, 2009
spring valley, California
ok so my wifes car blew her t25... so i put my freshly rebuilt 14b into her car. Now it drives awsome and pulls hard running wastegate only 10psi but every once and a while it will hit fuel cut in second and third. THere are no boost leaks i pressure tested and repaired all of them now it takes about a minute to go down to 5-6 psi and lingers there for several minutes but it still hits fuel cut a 10psi.:banghead:
hi im a newish member so cant start my own thread so i have to find threads relating to my problem... im hitting fuel cut on a car i just picked up..had an exhaust leak at the gaskets at the turbo. replaced.... come to find out the header itself is cracked.... but if i mess with the maft the fuel cut changes when and were it occurs... is there any common advice for this??? can a richen the maft or lean it alittle to lessen the chance of cut?? bc sometimes itll pull strong no cut at all (14psi) sometimes cut at 12.5.... i need help guys
