14b install
zcoh2gdsm
646
4
May 13, 2011
harrisburg, Pennsylvania
first time ive ever installed a turbo, so far everything except the lower IC pipe and the oil feed line (line on top of the turbo that goes to the oil pump) is not connected.
first, how do i redirect the lower IC pipe (stock) to the j pipe, its a huge clutter in there and it wont reach.
second, the oil feed line has a 90 degree fitting on the end (ss line) that when i took out the original oil feed line and unscrewed it out of the oil filter housing, there was a larger bolt that was screwed into. my larger bolt seems to be screwed in at an angle, i've tried taking out the bolt but it simply wont budge.
any help on these two would be greatly appreciated!
thanks, i already had the kit and whatnot, i was just blind to see that if you turn around the licp it'll fit. as for the feed, i just plugged it off and ran it from the head.
