FS: Wrinkle Gray VC & Calan Catch Can
gofer
Moderator
8,164
1,549
Feb 18, 2006
South Gilbert, Arizona
$300 (plus shipping) FOR BOTH
Valve Cover
This valve cover was powder coated WRINKLE GRAY with polished letters, with baffles installed. Both the PCV port and intake port and the valve cover have been tapped to a 3/8" NPT thread pitch to accept a 1/2" (3/8th" NPT) male fitting to run to a catch can. (see below)
Hasn't been bolted down to the top of a head since it was coated just over a month ago. Two (2) of the spark plug cover bolt threads are broken on the inside edges, however, neither effect the seal on the valve cover gasket.
Asking $150 (shipping & Paypal fees NOT included) and will include all SS hardware to bolt it down.
None of the photos are edited, just processed/cropped through PS. More pictures available upon request...
Click on images below to enlarge.
attachment.php
attachment.php
attachment.php
Calan Catch Can
Ran this piece of art for just a month before pulling it to help Craig do some R&D and a different catch can he makes. This catch can has (2) -8AN inlets and (1) -8AN outlet bung and WILL INCLUDE the two -8AN inlet hose end fittings and line going to the valve cover. Both fittings are black Earl's fittings and the -8AN line is Earls Pro-lite hose.
Asking $175 (shipping & Paypal fees NOT included) for the catch can, (2) -8AN Earls fittings and approx. 36" of -8AN Earls Pro-lite hose.
(WILL NOT SEPARATE)
This is the most cost effective way to run a sealed catch can setup since welding bungs to the valve cover isn't required and the above VC will include the 1/2" (3/8th" NPT) fittings to run this.
Below is a photo of the catch can installed on my car before I removed it, along with a photo of the amount of blow-by collected after 200 miles of driving and (3) 30psi pulls at the track. Nothing made it back to the intake track!
attachment.php
attachment.php
:dsm:
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
  • For sale 1g 91-94 ignition coil
    1g coil with harness side igniter harness. Digging in a box of remains from a yard six bolt for...
  • Wanted 2g Finish My Project!
    I am in need of some big ticket items in order to finish my project. In my engine bay there is...
    • dhssoccer24
