front sway bar bushing brackets
slick06emp
53
Apr 28, 2009
Lawrenceville, Pennsylvania
so i bought the rm 20mm front sway bar for my 95 tsi awd i started to install it but my stock brackets wont work with the energy suspension prothane bushings. is there a company that sells the brackets for the 20mm sway bar and the upgraded bushings? i am in desparate need. HELP
Why won't they work? If the bushings are too thick (as in, the bracket doesn't touch the subframe), use washers between the brackets and the subframe as spacers.
You need the RM bushing that comes with the bars.
Kevin
