Front Suspension
92Talon251
220
Sep 26, 2003
Fayetteville, North Carolina
My suspension in the front is basically shot, Is it ok if I do the front suspension and not the rear? I plan on using some KYB GR-2's and some urethane bushings. I wanted to use some new springs but I just want to go with some new factory springs rather then aftermarket lowering springs. Anyone know a good place to get New factory springs other than the dealer?
Thanks
:talon:
I've heard the GR-2's are basically the same as a OEM strut. So you can replace just the front struts, but why not be safe and do all four corners?
I've had the GR-2 struts before and they did a fairly good job. There are definitely better out there. But you said you want something like OEM, then these would be it.
Do it right the first time.
you must always replace shocks/struts in pairs, so as long as you do both fronts and/or both rears you'll be fine.
there is nowhere else to get OEM springs other than the dealer. I seriously doubt new OEM springs will help your ride, though. Replacing the shocks will probably make a noticeable difference if yours are dead.
His post says springs. But he mentioned the GR-2's (struts). He means struts/shocks, and yes I'm willing to place money on that. ;)
