Front Squealing while letting OFF the Gas, No braking.
FiReBReTHa
1,464
Oct 30, 2003
Aurora, Illinois
Ok
This could be premature because I have yet to check out the brakes.
The weird issue is. Recently had clutch job performed. a while after (three weeks) now my car is squealing from pass front while I LET off the gas, If I put on the gas and throttle the noise goes away.
but if i brake I do believe the sound went away as well.
Could it be possible that the bearings or something up there is out of grease?
Now the other thing if i let off the gas AND put the car into neutral the noise goes away as well.
soooo..... wtf?
Thanks thanks thanks!
theebluecrx said:
I'm guessing towards throwout bearing or wheel bearing.
TOB was replaced with clutch job, I personally think wheel bearing, how cost and replacement on those suckas?
I think maybe the grease didnt get filled or something and it burnt out.
selmerguy said:
check your belts. might be alittle loose.
nah, its right side def, belts are very good for once
