front speakers problem
LTUDSM
1,802
7
Jun 27, 2005
Morrisville, Pennsylvania
hey guys i have some problems with my front door speakers they are not stock they're Audiobahn's the problem is that they're so damn quite it looks like my rear speakers just playing ,but i know those front ones are in working condition, i dunno whats going on,my setup is
2 12's 1200 w both Sony Xplods (subs) which i m using audiobahn 1300W amp with them
4 speakers. 2 door 200W audiobahn speakers (reg size) 2 rear 400w audiobahn speakers 6x9 im using 1000W Kenwood Amp for those speakers.I grounded my system under the trunk's carpet,drill a hole and put a screw with a big washer and screwed down my cround cable. and i got no extra power for that ,i mean no capacitor or something like that. What are your'e guys suggestions???
i tried to do adjustments on balance both sides are set at the middle and a tried to fader them when i set full at the front the speakers still playing quite but i set it up at the middle ,my whole adjustments are good
are you running the front speakers off an amp or just the deck power?
And the amp doesn't have any adjustments for sensitivity? If so that may need to be adjusted.
Check to make sure you have the polarity of the speakers wired corectly. If one front speaker is out of phase, it will cause frequency cancellation and diminish overall sound output.
in Phase
AMP / speaker
Out of phase
Amp / speaker
it may possibly be a connection issue also. I had that problem when I wired up my radio my connects for the right rear speaker came loose and i would get very little sound out of them. Check your radio connects, if that's not the case, recheck the wiring on the speakers, then check settings on your radio, worst case your speakers are shot.
wait your running a amp to your speakers, have you check the crossovers on your amp? Make sure they are set to high pass filter, check your ground also and all the speaker wires.
