Front Prothane Motor Mount
Both roll stop sets from Prothane are designed to work in conjunction with the rubber in the center. It doesn't completely replace the rubber like it does for the mounts on the sides. You can either buy a replacement roll stop and use it with your Prothane kit, or you can check out the freelancer section for a full replacement urethane insert.
