Front brakes
sleeperhemi
82
Sep 22, 2012
White Plains, Maryland
Hi guys, just bought my first eclipse. Its a 1999 GS 420A. Runs great but realised that the front brakes dont seem to work. (no tags on it so we only move it in and out of the garage) other than the obvious repairs like new calipers and brake lines etc.....since im just starting to learn about this car....anything else I should look at before tearing the front end apart? Rear brakes work fine.....fronts dont....still have light rust on the rotors after moving the car around- Thanks
I have a set of brand new brake lines for the front right and left still in dealership packaging if you need a pair if your interested pm me. And also id go with new rotors since you can get a pair fairly cheap. And id check the proportioning valve also if the brakes arent working.
