brakes?
chris97pittman
242
May 10, 2004
Bellingham, Washington
I need to replace my pads because I've been experiencing shaking and squeeking lately and I was wondering If I'm replacing my pads on my stock rotors does it matter what size of pads I get and if it does, anyone know a site where I could find some performance pads not no name crap from shucks, that fit stock rotors, thank you
you shuld also get the rotors cut or get new rotors evry time you do pads
thats just crazy, ive never hurd of getting new rotors every time u do your pads, that would become expencive quick, allthough i do agree to get drilled and slotted rotors ;) while your down there u should get ss brake lines too :thumb:
he wasnt talking about drilled and slotted, hes talking about when they put the rotor on a lathe and cut it to make all the surfaces even. you should probably do that if it warped at all.
If your car is shaking when you brake, then you need to have your rotors resurfaced or replaced since that is a prime indicator of a warped rotor.
