fried safc?
clipse-T
111
Feb 6, 2006
Tyler, Texas
Is there anyway a SAFC can fry if i wired it incorrectly? I tried to install a SAFC first then i thought it didnt work so i got a SAFC2 and on both the buttons would light up and the screen wouldnt come on. Is there any way that i have it wired incorrectly for them to be fried because of it? Any help is appreciated.
Did you correctly wire the brown wire (ground) closer to the ECU then the black wire (ground) further from the ECU? That's the only thing I can think off that could be wired incorrectly for somethings to work and not others.
You could have possibly wired it wrong.
Check to make sure you have followed the directions to a T. http://www.ecanfix.com/~aclifford/tree/images/index/mods/superafc/afc.jpg
Also, you might want to pull the AFC's apart. Look at the screen, if you see a burn spot, the screen is no longer any good. This could be caused by wiring the AFC while the battery was connected, or an improper install (usually a bad ground).
