For Sale Freshly Rebuilt 7 bolt (2GB '98) long block
ohlegend
581
43
Apr 2, 2012
Pemberville, Ohio
Me an my buddy found a junkyard 4g63 in amazing shape and rebuilt the whole thing for experience and fun.
The only thing wrong was some bent valves.
I used Royal Purple assembly lube and The Right Stuff RTV for everything that required it
Everything was cleaned thoroughly and inspected. I have pics through the build so you can see what was done. No sensors are included because I cannot guarantee that they will work. I am including a working cam sensor though.
Asking 1500 + shipping (Long block is coming from 43450 @ 400 lbs)
Questions? text 567 201 8999 - Justin
Block:
Freshly resurfaced and bored .02 over
SCAT Forged rods with ARP hardware
Newer ITM .02 over Pistons
New ITM .02 over rings
New ACL Main Bearings
New ACL Rod Bearings
New ACL thrust bearings
New ACL Oil Pump
New Balance Shaft Elim. Kit - with MD128107 spacer (replaces BS crank sprocket)
New Rear Main Seal
New tensioner
New timing belt
New OEM oil filter housing gasket
Newer water pump
New water pump gasket
New ARP headstuds
MLS head gasket
Oil pan
*Block was cleaned with a wire wheel (Had awful blue paint), Primed with high temp primer and Gloss black high temp engine enamel.
Head:
Freshly resurfaced
8 New ITM exhaust valves
4 New ITM intake valves
NEW supertech valve seals
New Valve cover gaskets (all)
Stock cams
Stock springs
Extras:
Stock 2G intake manifold w/ EGR block off
New intake manifold gasket
Stock 2G exhaust manifold
New exhaust manifold gasket
All water pipes and thermostat housing w/ new thermostat
Valve cover w/ no cracks
Cam sensor housing with cam sensor
Fuel rail w/ spacers
Stock throttle body w/ egr block off caps
Stock Throttle body elbow
Lower radiator hose (a new spare I had)
  • Wanted 4G63 Wanted
    Looking for a kiggly HLA
    • steelcurtaindsm
  • For sale 2g 1998 Eclipse GST Rust Free
    Rust free, not perfect, prob needs motor soon. 125 compression all 4
    • Zanaqqq
  • For sale 1g Int door plastics MB517837 and MB517834
    • ist dwa
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted FIC Easytune
    Looking for a FIC Easytune box.
    • Stapl3
