greekgodchaos
- 565
- 212
- Jul 4, 2007
Vancouver,
Washington
Okay guys I've got a starting, running for a brief second and then dying problem here.
I've checked the ECU the Caps are fine nothing looks out of the ordinary,
I've swapped TPS sensors with no change,
Swapped resistor packs with no change,
Checked all my grounds to make sure they have bare metal contact, still same problem
The weird thing about it is is that it will start and run for a little bit after resting overnight, but then after that it won't stay starting. It simply fires up and then dies immediately.
I installed speed density and checked off all the settings and formatted it as per ecmlink instructions about running speed density.
My fuel injectors are dialed into the correct 850cc on link I'm running a 2G timing map because I am 2g Pistons,
Also installed BC272 cams
There were a few DTC codes yesterday, once it was the coolant sensor, then the CPS, then the TPS. But after clearing all of them, they haven't returned since.
Additionaly, I took it out on a drive before this all started, and it was getting hella phantom knock from not running synthetic oil (as I am at 4 miles into breaking in the engine.) Which was fixed by raising the threshold of knock to about 7000rpm. When the ECU kicked in, the RPM limit was 3000 and so I was poppin left and right. Took it out the next day, got 1 solid pull, then it started popping off on me again and dying. Then the problem with this not staying started popped up. Which brings me to here.
I'll be checking the coil pack and see if I'm getting solid spark to all plugs when my buddy comes over tonight, and I'll be checking my fuel filter sock in a minute so I'll post back with an update.
TL
R
Fresh motor doesn't run right, and it's a mystery waiting to be solved!
UPDATE 1: Pump Filter looks like it needs to be replaced so I ordered a handful that will be here on Monday.
UPDATE 2: Adjusted the TPS switch and it straightened out the idle very nicely. Now to find and repair those oil leaks on the front of the motor!
TL
RFresh motor doesn't run right, and it's a mystery waiting to be solved!
