Frankenstein 16G/T28 Turbo?
EAG13GSX
Sep 21, 2009
Concord, California
Okay so hears my question/theory: I have a Big 16g turbo with a cracked exhaust housing, I also have a T28 that is in pretty good condition other than the snapped center shaft. my question is; am i able to combine my 16G compressor wheel housing with the T28 exhaust housing?
Im not trying to sound like a noob but isnt the T28 Killer basically a T28 with a 16g compressor wheel?
and if i can get this Frankenstein of a turbo to work how much boost can it hold? the same as a T28? or 16g?:confused:
Help!:pray:
Don't bother. The machine work involved to put a T28 turbine housing on a TD05H wheel wouldn't be worth it.
Grab an ebay 7cm exhaust housing for under $100 and call it a day and get that Big 16g back and running. That T28 I'd use as a paper weight, not worth the cost of rebuilding it.
Nope.
You're talking about two turbos of completely different brands. Just like Mitsubishi pistons don't fit Honda engine blocks, a Mitsubishi rotating assembly will not fit in a Garrett housing.
