FPR Questions
That goes from the afpr to the return line on the fuel rail side, i got mine with the whole kit from them. THat looks like the install for the regulator, but i bought the whole thing.
If you have a spare input side conection with hose, you can ellongate the
2 bolt holes & use it as an output side.
Cheers !
many people choose to remove the fuel rail and tap the end where the FPR was with a 3/8 NPT tap then install a 90* fitting that goes from the 3/8 npt to AN-6 which supports the install of stainless steel braided lines to your new AFPR. The cheaper way out would be to use barb fittings and standard hose lines.
The kit you're wondering about looks like it includes everything you'll need, and it says it does too...pick it up!!!
Quick question, just in case. You do have an adjustable fuel pressure regulator don't you.
I went to help a fellow DSMer out and found out he was talking about the line from the fuel filter to the rail.
Thanks for your help guys... Its been a long hard road getting back into these things. I have owned a Cummins for last couple years and know a lot about those and what I did know about DSM's 5 years ago is kinda hard to remember today... Its like learning how to ride a bike again LOL...
