FP t28 wont boost past 18lbs!
Jets303
98
Aug 24, 2008
lakewood, Colorado
Ok guys i know its probably something simple but i have a bit of an issue. I have a FP T28 turbo i installed with an ebay mbc and it will not hold past 18lbs. I have the FP 17psi WG actuator so i can run at least 25lbs! Im not sure what im doing wrong. Could it be my MBC or do i need to adjust the WG? I have the MBC tapped into the top of the manifold. I tried it on the compressor outlet nipple and it didnt go past 10lbs. Let me know what you guys think! Thanks!
  • Wanted 6 bolt NT water pipe
    • chrisman287
