Resolved FP 68hta 2G install kit
PearlSweatshirt
140
Dec 10, 2013
Georgetown, Kentucky
Okay so I've decided I'm going to go with a 68hta for my 98 GST. I'm just wondering if they offer an install kit for this upgrade? Can I use the 16g install v2 on epsi? And what about my coolant lines, where can I get those? Unless they come with the turbo
I'm running the TD05 housing on it.
Same as installing a 16G...you'd need a j-pipe and an oil feed line. The rest of your existing parts can be modified to work.
You may want to hunt around for one of the older-generation "MHI-based" 68HTA's which came with a smaller TD05H turbine and 7cm2 turbine housing. The current release has a larger turbine wheel and 8cm2 housing which are great for big horsepower numbers but bad for spool.
Gotcha. Well I just wanted to redo all my lines as a piece of mind type of deal. So I was wondering where I can find some. And I did notice that. I might just give epsi a call and see what I can work out with them
JNZ can get you all the lines / banjo bolts. FP sells there manifold, 68hta, and oil feed line, as well as, there blue drain. Don't forget the gaskets and hardware!
