SBR FPR Install Kit for 2g
daren_p
DSM Wiseman
4,605
98
Nov 22, 2004
Newmarket, ON, Canada
I installed my aeromotive fpr with an aeroquip push lock install kit that I got from a vendor & I'm not happy with it. If I smell the area where it is installed I can smell gas fumes but I can't seem to find a leak, I've tried everything. I'm fed up with it & I think I'm just going to buy a new kit and start over. The SBR kit looks pretty good to me & I just wanted to make sure that these work well on the 2g's. It looks like there is a barbed or push lock fitting to be used with your factory rubber return line, does this fit the 2g return line properly? (not sure if the 1g & 2g have the same rubber return line size). I only ask because the kit that I already have was supposed to work with the stock return & doesn't so I had to add some fittings which I don't like either. So all 2g guy's, this kit fits perfect & no problems? Thanks
I have the SBR kit on mine. It uses a barbed fitting for the stock return line. Mine works great, and was practically bolt-on.
I was wondering if anyone knew exactly what parts came in the kit. I can get the fittings real cheap and would rather do that then buy the kit. If anyone has a list of what it comes with let me know. I could probably offer it for much less.
I also have the SBR kit on my car. The outlet fiting from the fuel rail is a little tight but works just fine.
