Found Boost leak
Riceless92TSI
Dec 1, 2010
Carson, Nevada
I found a boost leak it was leaking from idle screw on the throttle body ,how can i fix it from leaking from the screw.
Make sure you properly set you idle afterwards by grounding out the diagnostic pin. Vfaq should have a write up on it. What other leaks do you have? You did use soapy water and at least 20psi on your test correct?
If a new o-ring doesnt fix it, I suggest figguring out what yours needs to be set, marking with a fine tip permanent marker, letting that dry. Then pulling it back out and applying some thread sealer, or silicone forma gasget to it. You don't need much at all.
Yea replaced the oring and the leak went away but my boost gauge vacuum is at -12 to -14 and my car is running very lean and cant find another boost leak. I have a 2g maf and 560cc injectors so i thought it would run rich. I dont know if i have another boost leak or have a bad cam sensor or something else.
yea i put 25 psi in the motor but cant find any other leaks but im still running lean and cant find out why and im running a 2g maf and 560cc injectors
