ford throttle body, questions?????
1995badgsx
80
May 27, 2004
columbia, South Carolina
i know theres topics already but none really answer anything, i bought a 96 gt bbk and the flange will not bolt up (BJ intake) but the throttle cable works perfect, a buddy said run a 86-93 the flange is right but the cable will not work??
and i would also like to know how to wire up the TPS
any help will be useful!
thanks
thanks
The FRH's use a 96+ GT, BJ's I believe is 86-93 GT t/b bolt pattern. What are you wiring the TPS to? Standalone or stock? Specifics :)
using dsm link with a translator
Honestly, you'll spend a couple days on here asking for the wiring.. it's 4 wires, guess :D I did my TPS and CAS like that, just look at your logger and when the signal reads right, solder the wires togather
