Throttle Body, TPS, AND cas Questions.
BowDownRacing
65
Jan 12, 2013
Torrance, California
I have searched to ask which is the best throttle body I am running a JMF Drag Manifold he is in the process of making all my parts right now I need to know which is the best throttle body on the market Im shooting for 900hp any help is appreciated, also when deciding on tb I need to know which tps to run. I will be running the Kiggly 12TOOTH Crank Trigger which CAS should I use. I dont know if this is the right section for this I just need help asap so I can get some parts ordered and let JMFAB know what flange I need on my intake manifold Thanks in advance.
x2 I am at 666Hp Mustang dyno JMF intake with stock TB. Upgrading cams to S3
Wondering if 70mm throttle is worth it.
