Ford injectors fit?
MarcVIII
103
Oct 23, 2004
Cleveland / Akron, Oh, Ohio
I have some Ford injectors lying around from some old projects. The sizes I have are: 16 & 28 lbs/hr. Fist off, about what size are these suckers in cc? They appear to have the same plug style, but they may be a little taller. I haven't held them sext to the originals to see if they are or not. Would I be able to use em if they fit?
I'm basically stock but am installing a TuboXS mbc, gutting the cat, doing all the free mods, and a 1g bov. I might add a dp, but I'm going the cheap route first cause winters coming up. Hopefully this will all get done this weekend.
Your ECU only has a correction capability of 10% from the stock injector size. If you're upgrading or downgrading injectors greater than 10% you'll need a S-AFC2 to compensate.
I haven't a clue about the size etc... I would not suggest it though.
NO!.. do not use these injectors. I work for a ford dealership and these clog uncontrollably and they cannot handle much of anything. Get some stock 1g injecors from a 6-bolt. those are some of the most reliable and powerful stock injectors in mitsu. lineup. FORD stands for- Fix Or Repair Daily.
good luck bro.
Some one correct me if I am wrong but i believe that 16 lb injectors and 28 lb injectors will translate to somehwere around 180cc(16lb) 300cc(28lb) injectors. So you would be better off keeping the stock 450cc injectors.
this is correct. :thumb: also Eclipse injectors are low impedance and i don't think the ford ones would be. :dsm:
plus its ford :barf:
