Ford 75mm TB IAC Question
Batman™
176
Dec 11, 2006
Shaw AFB, South Carolina
First off, I searched and found basically nothing on this topic. I need to know a couple things, and am hoping that someone on here has worked with the Ford TB.
I bought a Ford 75mm TB for my 2G Eclipse GSX Project. Unfortunately, it came with the IAC Valve blocked off. This raises worries for me, as I don't want to have to worry about cold start issues and the like.
To top things off, I saw on DSMTrader that a guy has a 75mm TB for sale that comes with the IAC, and it looks to be wired for a DSM, which I'm guessing is the case.
Now on to the question. I looked at Accufab's website, and they sell a Chevy IAC Adapter for the Ford TB. After careful inspection of the pictures in the guy's ad on Trader, I believe that that's exactly what he has. So... when I go to mount an IAC, do I need to buy the Adapter Plate and install a Chevy IAC? If so, how is it wired? Is it even possible to get away with having an IAC on a Ford TB?
Please help me out here, this has got me slightly worried. I'm putting a LOT of money into this motor, and want no issues whatsoever. Thanks in advance.
-Charlie.
Anyone? I could really use help on this, and I know someone on here has had experience with it.
I'm also looking into Idle air control on a 75mm ford TB setup with an AEM EMS is it necessary to use the Jackson IAC setup?
https://www.jacksonautomachine.com/html/shopping/list_section.cfm?sectionId=33
with AEM there is an option to just use the ford IAC readings. unfortunately this is not the case for everyone that doesn't have AEM.
to answer batman's question, a friend of mine has just come up with a 1g/2g to mustang tb ISC adapter plate. this allows you to bolt your factory ISC up to a ford throttle body, no extra wiring or headache. i posted pics in the other thread, this would probably be your easiest solution
