1G Fog lights: 1ga vs 1gb
Cox Abele
485
56
Jul 4, 2010
Roanoke, Virginia
Is there a difference between 1Ga and 1Gb fog lights? Found a 1gb with fog lights in the junk yard and my 1ga could use a set. Are they interchangeable?
Im not asure i know there is a definite difference be5=tween gb eclipse and gb talon fogs,
Eclipse fogs:
taLON ONES
THE TALONS BOLT ONTO THE steel dumper support while the eclipse ones have a bracket and bolt to the frame.
Multiple sources say they are the same. I have recently been looking into getting new OEM ones. Apparently the part numbers are the same 1990-1994.
Eclipse's are the same 90 to 94, Talon's are different between 90, 91 and 92 to 94. The whole anchoring system is different in addition to the actual housing as shown by the pictures above but I am not sure if they would be compatible with each other. The P/n will be the same if found on ASA because it would only pull the number for the Eclipse ones.
I hope this should clear it up, I read this thread while at work and decided to look for myself. our system comes back with this
Well, I pulled them from a 1GB Eclipse, but they seem like they'll work great once I bolt them into my 1ga laser.
  • Wanted 6 bolt NT water pipe
    • chrisman287
