fog light switch
Never tried it, but just be aware of the current draw. If you need to, you could always use that signal from the fog lights to switch a relay on/off, so you can feed the load directly from the battery.
I THINK your 97 has a 2 pin connector at the foglight? You can get a connector that plugs in there, and then run the wires to your new load. JNZ has those connectors I think.
