FMU for TSi?
DSM_AWD_TSi
124
Jun 26, 2003
I'm looking at some fuel management options for my future upgrades. I know the fmu basically raises fuel pressure with boost to squeeze more fuel in with the same size injectors. I found that the Cartech FMU's can be set to turn on at a preset boost, so if I'm running out of fuel at 8 psi, it'll raise the fuel pressure at that point to give more fuel. My questions is, will this idea work? Anyone using it? Thanks.
If your looking to turn up the boost on the car, you'll be safe to about 14-15psi with the stock set up. The stock fuel pressure regulator that comes on the car is a rising rate regulator, which means that it will raise fuel pressure 1psi for every psi of boost it sees. When you upgrade your fuel pump, then a adjustable fuel pressure regulator will be needed. After that, you might want to look to see if you have an e-prom ecu. If you do, look into getting it flashed. I don't believe the FMU works well at idle and mid throttle. Only at WOT. With an upgraded fuel pump the 450's are good for another 2-3 psi, and then they are pretty much maxed out. I hope this helps.
  • For sale 4G63 NEW! old stock 6 Bolt Timing Cover
    Brand new old stock in box OEM Mitsubishi 6bolt lower timing cover. This has never been on a...
    • Dustin90awd
  • For sale 4G63 ARP crank bolts and 7 bolt Fidanza flywheel
    Details 7 bolt light weight aluminum Fidanza flywheel, pressure plate bolts and new ARP 7 bolt...
    • Dustin90awd
  • Wanted 2g ABS - Left side harness brackets
    Looking for the metal brackets for left side ABS wiring harness. Sensors not needed
    • Justin DuBois
  • For sale 2g 2G DSM ECU
    $100 picked up 91605 CA $100 + Shipping Need gone don’t have the space for it.
    • Stizzydrew
  • For sale 1g Door cards
    Grey very good condition, pick up only
    • 93 talon tsi awd
