Fmic
You'd need to do some minor IC pipe modification...I bought one similar to this and its been nothing but AWESOME for me...it has kept my IATs down lower too allowing for higher boost. I would get it, cut your bumper support a little and stitch weld it back for strength and let the fun times begin...
I see nothing wrong with it. I'd probably opt for a larger core (Taller and Thicker). But CXracing is where I got my core and it has been great!!
Just modify the pipes and you can get it working!
You'll also need a J-pipe coming out of the turbo that points towards the driver's side.
Short answer - no.
Why? I'd like the long answer.
I was answering his question regarding whether it would bolt-on. It won't. Can he make it work? Sure.
its a universal kit.. it will most likely take some cuting and fabing to make it work correctly
Yeah the kit will fit with some minor mods to the piping and front bumper. Good addition to lower your temps.
when you say cutting and piping modifications exactly what kind of modifications and what would i need to make thes emodiications?
a dremel, or a hack saw, or a band saw and a most likely a drill. you may need some plate alum to mount the intercooler to the car
The piping isnt fitted to your car it has to be cut to fit so from the time it starts at your turbo an all the way to the intercooler needs to be cut and positioned. You will prob need a reducer from the j pipe to the i c piping and then one from the i c piping to the throttle body elbow. You also have to get a blow of valve in the series somewhere an usually you need a bov flange an have it welded to the piping.
  • Wanted 6 bolt NT water pipe
    • chrisman287
