fmic too small?
tlikethedrink
361
92
Sep 11, 2007
ABQ, New Mexico
Looks about like the one I put on my dads stealth, and my storm, it worked pretty good but i didnt ever go above 16psi, it stayed pretty cool when i felt it after driveing hard for a while. It all depends on how much power and PSI you plan on pushing.:laser:
well -15 psi.
top power... whatever i can get out of it. i should have 2.5inch cat+back exhaust, this FMIC + custom pipe, and the boost up'd to about 13-14psi. i dont know what kinda numbers i would be working with, but thats about all the "big" things... i would like to hit 200-225whp
well -15 psi.
Sounds to me like it will work just fine for you. The one I have is good up to 30 PSI, it says. :laser:
well -15 psi.
Doable on the stock 2g SMIC in my opinion, but that FMIC will work as well obviously.
well i already have it.
i know the numbers im shooting for a well within reach with the stock side mount, if i were to use hard ic pipes.
i figured since i wanted a fmic setup and need new piping anyways might as well go with it. plus all n all i think ill have it all goin for about the price of some hard pipes.
if/when my t25 craps out... then i plan on a 14b, unless i come across a good deal on another turbo.
