FMIC Set UP
GSX'er587
183
May 9, 2004
Novi, Michigan
I was wondering if anyone had any pictues or explanation on how to mount tne intercooler and also what all needs to be done with installing it such as relocating lines and all that good stuff. Pics would help but if you can just explain i'd appreciate it. Thanks :dsm:
which FMIC
my hahn FMIC mounts where the stock holes are for the fog lights
then uses metal spacers and studs
here is a pic i took before i put on the IC. i circled the bolts that are removed and replaces with the IC studs and spacers
i also had to move the hard line seen in front to behind the radiator mount
not hard
just an inconvenience
Be more specific as which fmic u r installing and then u can get input from people who have installed those particular fmic.
Its a custom intercooler both inlets are on the bottom. Other than that theres really nothing much else to say about it. It's 24x10x3 with 2.5 in inlets
my advice is use the search button...type in fmic install or something and read through. Places like dejon tool have install tips. The one thing i can tell you is that you will most likely have to relocate or completely remove the power steering cooling line by shortening the power steering line; that requires some cutting. And if u r doing short route piping, you might have to cut in between the radiator and passenger headlight to let the pipe thru.
Good luck
