fmic piping, what bends?
brisk42
Aug 7, 2006
oakland, New Jersey
Well i just bought a buschar fmic with the lower piping but no upper. So i was looking to just buy some piping, couplings, and clamps, seperately to make the upper portion. I just need to know what bends and coupling i will need, any help is appreciated
I am not sure what a buschar fmic core looks like but if you can make your upper pipe a short route. Mine is a 2g but a 1g should be similar. The same principal the shortest route from the FMIC to the throttle body is best.
Here is the pipes I needed to make mine short route. They are circled They are 2 1/2'' pipes. For the couplings you can buy truck water hose at your local parts store.
You will have to cut a small piece out of your radiator support. That is circled in this pic. IMPORTANT: You wire harness runs in this area too, be sure not to cut it.
This is what the piece you cut out should look like.
The short route gives you a cooler intake charge. It is pretty much a straight from your FMIC to your TB
