FMIC install
dkrugg24
84
Dec 30, 2010
Sterling, Illinois
i recently bought a FMIC and was wondering what to do with the power steering line that loops around in the front of the car where the intercooler goes do i just do a power steering delete or is there a reroute kit for it?:confused:
ya makes sense just didnt know since it was a steel line if i would be able to move it anywhere without damaging it or bending it or if there would be room between the intercooler and the radiator and everything else inbetween
That's the power steering cooler line. You can generally eliminate it without any ill effects. You can also to what the above poster did and re-route it behind the hood latch support. You do not need to eliminate power steering all together to eliminate the line. If you loop it, you loop it at the reservoir.
a little off the thread here but curious because ive thought about doing this myself... how difficult was it to do an AWD swap?
ok sounds like a good idea thanks for the info.
    • dsmmario
    • Detail
    • dsmmario
