Flywheel bolts
Talonnightracer
Dec 23, 2005
Perrysburg, Ohio
I was wondering if anyone knows how much stock flywheel bolts costs? Also does anyone know the demensions of the bolt so i could get a stronger grade of metal? If it would be need to get the stronger grade of bolt?
i would also stick with OEM, they are relatively cheap and they should hold up for you, unless you plan on making like over 1,000 hp, which is very unlikely
I just got a set of new flywheel bolts from maperformance with my new flywheel ...the bolts cost 15.99 for 6 bolts and they are oem ...
If I remember corrctly TRE sells a bolt kit if you can't get one at your local mitsu dealer.
