Flywheel bolts
dale187
292
Jun 28, 2008
Dover, Delaware
Hey guys need a quick answeR. Im doing my clutch today and i need some advice. The last time i did it i put a new flywherl on it. But i spripped a couple of the bolts. Well i had a couple 1g bolt bolts laying around and i used them. So i have like 4 or 5 2g bolts which are 17mm and like 2 6 bolt which are 19mm. My question is since the heads arr bigger i am afraid of the flywheel being off balance. But i am Also afraid that if i try to remove them i will strip them. And the last time that happened i had to cut the flywheel off. So do you think I'm just worrying to mucj and i should be ok?? I just want everything to be perfect.
I think you answered your own question when you said "I just want everything to be perfect". Also having to cut anything off of an engine is very bad, next time you tighten anything make sure to tighten to specifications, no stripping and much less headaches for you down the road.
