flywheel bolts keep snaping
dtsbmx666
Nov 20, 2004
binghamton, New York
i keep snaping flywheel bolts everything is being done correctly and to spec. and i can not figure out why it is doing this is someone have any type of answer please feel free to help. i am in a big bind. i jsut bought a new flywheel and lock tite (blue) im hopeing this will fix my problem. please help!!!!!!!!!!!!!!!!!!11111
Well did you buy brand new flywheel bolts? Also I would use a different tourqe wrench because your could be off and over/under tightening the bolts. It also says to use loctite or a similar substance. Personally I used red locktite and have never had problems.
just so i am not confused what exactally is the dowel pin and where would it be missing from. cuz i have to car apart right now . please and thank you
