Fluctuating Oil Pressure
Status
Not open for further replies.
94_eclipse
153
Jan 19, 2007
Shelocta, Pennsylvania
I noticed in my car lately that the oil pressure gauge will go up and down. If i am driving and on the gas its normal, right in the middle of the range on the gauge. But the problem is when its at idle, the pressure will drop down, it will still read that there is pressure but instead of being at the middle, its about 1/4 of the pressure. Is this normal, any suggestions?
Sounds normal to me, when the car is at idle there is no load on the engine to generate oil pressure.
When you turn on the headlights or any power draining accessory most of the time it will drop the idle a bit because of the alt.
Status
