Boost fluctuating
1stGenTSi
323
Apr 8, 2005
Austin, Texas
Installed my hx-35 a couple months ago and I just started having an issue with the boost fluctuating. It seems to only happen in 5th gear when flooring it from about 60-75. Only running about 17psi right now and at full boost my boost gauge bounces back and forth from about 14-17psi quickly. Second and third gear pulls hold steady to red line. Fixed some small boost leaks but it's still there. Running ebay 38mm off o2. Any ideas?
Using a Joe P mbc with a 1bar spring in the wg, all hard piping. I'll try running just wastegate pressure to rule out the mbc. Thanks for the replies.
