fluctuating idle
Boostedexcel
133
Sep 22, 2005
hidden hills, California
The engine is completely stock(91 6-bolt, 4G63t) with the exception of a 16g. The car drives perfectly normal except at idle. The vacumn bumps up and down from 20 to 22hg, it almost sounds like I have aftermarket cams. When I first got the car, it would randomly do this...all I had to do, was the turn the car on a off and this would fix the idle. Could it be the junky Ig maf, vacumn leak, or IAC????
let me know if you figure it out, because someone i know is having the same issue.
