Floor lamp question
joshhuha
Mar 26, 2012
Mantua, New Jersey
i been looking on superbrightled.com and im not 100% sure what type of light would be down by your feet when you open your door. can anyone help me out!
192, but i used a larger 168, but you can use anything with the 192/168 base. Im planning on using LED strips and soldering a custom base to plug them in and running them all the way across each side. More light, less heat.
I bought 2 12" LED stips and super glued them to the bottom of the dash on each side of the car. Wired them up and bright as can be. I also didn't have the option to use a bulb since the previous owner of my car was into neon tubes...
