flex plate spacer removal
I didn't even know we HAD those... is that only a 2g thing? Or an Automatic thing? Do we need it? Where can we get it? I wouldn't think we would NEED one of those right? ...wow...
Just for a little more info..the n/a is different than the turbo. The turbo # is MD732972. The spacer holds the torque convertor centered to keep from beating the bushing out of your front pump.
I had to knock out an n/a spacer and buy the new one about a month ago. (I used an n/a crank to build my new engine)
Has anybody used any other methods to remove this spacer? I'm having trouble with the toilet paper trick or using vice grips.
I'm guessing I may have to use the air compressor and air hammer?
I just use a good pair of vice grips. Attach them to one side and tap it with a hammer, switch to the other side and repeat until it is out. It usually takes about 5 minutes to do.
I just do not understand the toilet paper always works. You have to make sure the socket fits snug and just tap it in with the wet paper.
You have to keep stuffing it and compacting it. If the socket is to small the wet paper will squish out around the socket and will not apply force to the backside of the spacer.
I tried the wet tissue paper for about an hour. Finally gave up on that and just kept smashing it with a hammer and trying to twist with vice grips. Finally got it off. Hope you get yours off! Haha
Grease packed into it and then use a socket or punch or whatever will go in the hole snug will hydraulically push it out if you smack it and keep packing grease in it. Yes it is a bit messy but that is what we used to remove pilot bushings in farm trucks crankshafts and usually used an old input shaft as the tool of choice for the correct diameter to fit in the back of the crank. Just MTC.
This is definitely the easiest way to do it!
Measure the I.D. of the spacer and go to Home Depot/Lowe's and buy a wooden dowel that's got the same O.D. Pack the spacer with grease and hammer the wooden dowel into the center of the spacer, it will pop right out.
