Fixed no-start prob, firing order is WIERD
Tri-Edge
49
Sep 20, 2006
New Milford, Connecticut
anyway after chaning coil and PT, and plugs wires etc...i found that the firing order my car likes to start with is 3214 rather then the normal 4123....why would this be??? it seems to be completly reversed...im so confused...
hmm..it was brand new with a bracket and i just mounted it..and the numbers on the coil pack were right side up...unless they are supposed to be upside down...
Actually for a 2g the firing order should be 1-3-4-2 (which is probably what yours really is) but you can make it appear to be anything you want by reversing the power transistor connections and the coil primary/secondary connections.
I cant remember the sequence, but if you have a 6 bolt motor in a 2g car you have to reverse two plug wires, my car is like this.
Jamie Sanders
