First Start, first post, 1G CAS question
jw4free
147
76
Dec 3, 2008
Billerica, Massachusetts
Started my car for the first time in 6 months. Did a couple mods. Relocated the batterty to trunk, Bought DSM Link V3, redid the intercooler piping, Messed with the engine wiring, etc.
Finally hooked up Link to the vehicle and downloaded the settings. I have a non 95-96 CAS, but that box was not checked off in Link. Didn't reload changes to the file.
So I hooked up my electic fuel pressure regulator to see if I was getting fuel to the fuel rail.
Started cranking the engine to check gauge, and the car actually started. Awesome, but suprising.
Should the engine fire with an non 95-96 CAS even though the computer is expecting an 95-96 CAS signal?
It's my first Post. Been lurking for a while.
Did it stay running? I dont have a dsm link but when i did my motor swap and I tried to start it I didnt realize I didnt have the cas connected and it was start then sputter then die right away.. Not sure if the dsm link would make a difference but without it I did get the motor to fire..
I captured a log of the first set up, then loaded the non 95-96 CAS Setup file and ran a log. It appears that making the change affected my baseline ignition timing. The non 95-96 CAS setup decreased the timing about 10deg.
