First Mods and Lessons Learned
PXHero
175
16
Aug 19, 2008
Columbus, Ohio
After almost a year and a half of having my beautiful 1999 Barcelona Red (purple) GSX I finally got around to some mods.
I started with a Megan Short Shifter and a Symborski bushings kit. Except for breaking a bolt:ohdamn: on the shifter plate the install went smoothly, luckly I managed to extract the broken portion and replace it with a machine screw of the same size and thread:thumb:, maybe I'll replace it with a factory bolt down the line:hmm:.
My next step was to lower the car with the Megan 2" drop springs. This proved to be a bit of a hassle. The rears went smoothly, and I replaced the shocks since I could compress them by hand and they wouldn't push back out:thumb:. While I was buying shocks, I also bought fronts as well, figuring they were probably bad too (and they were). I got the rears done and lowered in a little less than an hour. The fronts took me close to nine hours (of actual work) due to the siezed bolts in lateral control arm bushings. Thankfully I have access to a shop with a sizeable air compressor, die grinder, and plentiful cutting wheels:thumb:. Over the course of the next four days I purchased new lateral control arms, pivot bolts twice (once having purchased from Lowes SAE bolts that were a hair to thick), shock fork retaining bolts, lock washers and nuts, and managed to lower one of the fronts. When I finally got around to lowering the other side I was soooooo proud of myself, and very satisfied with my work:D.
I've had the car lowered for three days now, and just last night I encountered a problem. While driving home I lost all steering, the front driver suspension just collapsedOMG, and a horrible grinding noise emminated from my wheel:cry:. Come to find out that the ball joint nut on my freshly replaced lateral control arm hadn't been tightened properly:ohdamn:. The nut, now missing, had worked it's way off and the ball joint finally gave under the pressure. The sudden lack of support caused the axel joint at the wheel to bend past tolerance and at the very least shred the boot, I'm still waiting on the total damage report from the repair shop.
As for lessons learned:
1. The metal cup that holds the dust cover on the shock is actually important, don't throw it away:ohdamn:. It acts as a washer for the bottom side of the bushing at the top of the shock, with it in place you won't see your shocks come into your cabin or through your hood.
2. Make sure to have a lot of penetrating oil, and actually use it. "PB Blaster" or "SeaFoam Deep Creep" work best from my experiences.
3. Be sure to lube the contact surfaces of the lateral control arm bushings and retaining bolts from time to time to avoid a lot of cutting and replacement costs.
4. Above all, when tightening a nut on a ball joint, make sure the nut is spinning, and not the joint:thumb:.
Good info man and I hate to hear what happened to your car. You live and learn though and thats what it's all about.
That ball joint is always a pita to tighten. I usually used a 6' c-clamp to hold everything tight together than blast it on with an impact.
I also got it on there once by putting a jack under the strut and jacking it up until they were pressed together. I couldn't find my c-clamp on this occasion though, as it would have been much easier.
Sorry to hear man. But an impact gun is NECESSITY when working on the suspension for these cars. I lowered my car by hand the first time too. Took me a good 10 hours. Never again.
I do have an impact, 1/2" drive Ingersoll Rand... problem being that I don't have a 22mil impact socket, and couldn't have gotten access to the nut because of the drive axel connection being directly above it. I didn't want to remove the entire wheel assembly, but looking back I probably should have... Thanks for the sympathies...
You have a gsx and your first mods were a shift kit and shifter and lowering springs :ohdamn:
I'm still fairly new into cars, so I thought I would take on some of the "easier" mods... Once I find a DD I will be doing a complete garage tear down and rebuild... and with the way the "easy" mods went I'll be needing a lot of luck, patience, time, money, and penetrating oil...
Once again that is your feelings on what is right. What is right for you may not be for another. Not everyone does racing. More actually have DD instead.
I hear ya I'm not trying to push my ideas on him but he did say he's looking for another dd so this is not going to stay his dd with that said the shift bushings ok I can see but I think the megan springs money could have been spent better.
OP
Shitty news. It always sucks when you've got great intentions, problems, solutions and more issues, welcome to wrenching on a 10 year old dsm. I've torn my suspension apart about 3 times now, I replaced bushings which sucked but "freshened" up my suspension bolts. Dealing with all those bolts exposed to road grime for over 10 years really sucks, but after taking it all off once your golden. I'll be replacing my tein springs with some sleeve coilovers and don't expect to spend more then an hour replacing them w/out compressed air.
Just remember that the rest of your car is also 10 years old. Bolts are gonna be hard to get out and you may break a few more replacing parts. With your replaced shifter bolt, if the tread pitch is the same as an oem one its not gonna be any better/worse besides a uniform head. Also remember that its a dsm, I usta hate people for making fun of dsm for always having issues but... these cars (2gs) do have issues and were designed with absolutuly no race potential (like they fell off the page) besides the engine which wasn't really new (well besides crankwalk). Just look at your suspension compared to a 1g, have you noticed that our cars have some volume to them as were the 1g doesn't? They are sexy but at the end of the day you don't see many 2gs racing besides drag cars, which go straight.
