ECUflash First evoscan log, how does it look?
saechao04
462
3
Aug 8, 2006
portland, Oregon
Hey guys, just got done doing a couple of pulls and logging with evoscan. How do things look? I have a wideband but haven't installed it yet. Also I have dsmlink but haven't installed it yet. Bought it used and don't know how to use it yet. Trying to keep it as "stock" as possible while breaking it in.
Mods:
fp2 cams
MR exhaust
wiseco/manley rods/pistons
FP BT28
stock 450 injectors
Hitting 109% Injector Duty Cycle at 5600 RPMs.
Time for some bigger injectors.
(Also not sure which protocol you are using, should use MUTIII with a 99 ecu, sample rate seems low, but I might be mistaken)
My friend, checked everything to log, so there were like 25 different things to log. Would it be wise to just go ahead and use dsmlink since I already have it? The shop told me to just keep everything stock until after break in, that's why I'm not using it. I do have 880 injectors too. Currently at 150 miles on fresh rebuild.
yea you wanna log load as well . umm dont log speed afr map, on wot pulls... also looked at you o2 sensor value and something doesnt look right... its .11 on wot sections... it should be in the.9 zone. im gonna assume its bad because the engine would have broken up going into boost with readings like that. but log looks good.
Thanks hediki, I think it may be my o2 sensor, my check engine light just came on while I was at idle, correct me if I'm wrong, but evoscan can scan for codes right? Well it pulled up code P0170, fuel trim malfunction [bank 1], ordered a new front o2 sensor.
Got new front O2 sensor and a new downpipe gasket and the problem seems fixed. I'll get another pull in, at 500 miles I think I'll put in the 880's, walbro 255, wideband and dsmlink.
