First DSM. how much can it handle with my build?
defeat54
50
Oct 18, 2011
MONTGOMERY, Alabama
How much boost can the car safely handle with this build? Will be taking it to a dyno.
--Engine--
-The motor has all forged internals, Eagle Rods, Wiseco Pistons, Polished Factory Forged Crank, Acl Race bearings, Arp head studs & main studs, Supertech Valves, Springs & Retainers, mild port & polish
-Hot Tanked Engine Block/ Bored (.40 over) & honed / repainted block
-Wiseco pistons (8:8:1 compression) & Eagle H-beam rods
-Mild stage 1 Port & Polish with 3 angle valve job
-Supertech valves & springs w/ titanium retainers
-BC stage 1 camshafts
-Prothane Engine mounts all around
-3" Exhaust from the turbo back with Greddy muffler
-Garret .60 trim T-3 turbo water & oil cooled with polished cold side housing (Just rebuilt >300 miles on it) no shaft play.
-Greddy type-S blow off valve
-Innovative 38mm wastegate w/ 10lb spring
-Iron T3/T4 log style a/c friendly turbo manifold
-Front mount intercooler 32x17x2.5"
-2.5" polished Intercooler Piping
-Vibrant 6 ply high temp and reinforced couplers
-OBX Intake Manifold
-Fujita High Performance air filter
-Blue wire loomed the whole harness
-New Gates timing belt and pullies/ New water pump
-Fluidyne Full Aluminum Racing Radiator with 2 12" fans that run constant off the ecu
-Obx upper and lower 6 ply high temp radiator hoses
-1g gst blue top 440cc injectors
-Obx red high flow fuel rail
-Sard fuel pressure regulator
-Walbro 255lph fuel pump
-Vortech SFMU with full fuel trim adjustment
-GM 4 bar MAP sensor with pigtail harness
-Apexi Safc NEO A/F controller/tuner
-HKS Turbo Timer with Multi Functions and V. display
--Drivetrain--
-Full 5spd swap
-SPEC street and track stage 2 clutch
-BLOX 392 gram Weighted shift knob with B&M short shifter
-Brand New Napa Axels (rated to 300+ hp)
-Endless braided clutch line used with dot 4 fluid
-New napa clutch master and slave cylinders.
Anyone know a good place to have these cars tuned in Montgomery, AL area?
