First Auto need help/advice
jdmspilner
118
Dec 19, 2004
Houston, Texas
Heres the deal, I just picked up a 92 Talon AWD auto. It has 89k on it and a rebuilt trans that works fine. It is all stock right now. Here is what I am planning on putting in-
2g piston motor with no b shafts
Denso 660 injectors
ported head
td06h 20g with 8cm housing
big FMIC
2g maf
cams of some sort
I want to know what needs to be done to the tranny , It has a stock cooler on it and I was planning on adding another. Maybe a shift kit. Also, I heard about a timing mod but cant find any good info mods.
You should buy:
TransLab Shift Kit
IPT End-Clutch Kit
IPT Manual Valve
IPT Transmission Cooler (19,000 GVW)[you don't need to keep the stock one]
There is a wire going to the ECU that pulls timing during shifts. I will try to find the wire number for your. All you do is cut it in half and put in a switch if you want.
Also, if you want full pressure shifts (which are very firm and quick) or manual control, you can try this out:
DSM Classifieds - Message - Powered by PhotoPost Classifieds
