garrek11
- 201
- 1
- Apr 4, 2009
Spokane,
Washington
Ok so let me start off by saying the car ran fine before these changes occurred. I have a 89 mirage with a 4g63 swap (90 dsm). I started blowing out spark so I decided to go with a ARC 2. Installed the ARC 2 per the write up that was done on here a while ago by swapping out my 90 coil pack for a 91+ coil pack blah blah blah. Put the car back together went to start it and wont start. So I switched the wires around on the coil and the car starts up and idles really rough / lean and dies if I let my foot off the gas. So I thought that maybe the injectors might have gotten switched around. They all checked out and were plugged in correctly. The next thing I tried was started the car up and had a helper unplug 2 of the injector clips cylinder 1-2 when they unplugged one of them it did nothing but when they unplugged the other the car died out. Im guessing one of the coil packs are either bad or the firing order is mixed up and I might need to invert it on DSMlink. Is there anything else I should do to eliminate any other possibilities? Any ideas are greatly appreciated.
