jibberishballr
- 475
- 3
- Aug 23, 2005
Chico,
California
I just finished my compression test and my boost leak test. No Boost Leaks. My compression test showed 173-178 across all 4 cylinders which im assuming is good. Heres my problem. My car burns/leaks oil and i eat up quarsts of oil within weeks.
So heres what i know for sure:
-NO Shaft Play
-My car eats oil like crazy. Were talking a few quarts in weeks.
-I cant see any oil leaking anywhere (none in engine bay and none on ground)
-My friend said when i take off (accelerate hard he sees smoke)
-I dont see smoke at any time so it cant be that big.
-My friend couldnt tell what color it was but thought it was grayish (the smoke)
-The oil gets really dark...black black
-My car seems to burn more oil when i run it harder
-Spark Plugs are fine
-Compression is good
-Didnt need to do a wet test because all cylinders were fine
Where do i go now?
-NO Shaft Play
Where do i go now?
....I'm running out of ideas...i still have to check the lower intercooler piping for oil and the return line from the turbo to the oil pan...thats all i can think of. Any other ideas?
