Fidnaza Flywheel gear came loose
Mph
171
Jan 7, 2010
Naperville, Illinois
I tried starting my car and the starter would not engage with the flywheel. When I checked my flywheel, the outer teeth were not aligned with the notches in the center of the flywheel.
You can see in the picture there is 3 allen head bolts that hold the outer teeth to the actual flywheel. These 3 botls came loose and the gears spun without turning over the motor.
I tightened them up with lock tight, and the motor turns over now. Does anyone know what the torque specs would be? How to keep this from happening again?
Wow ive never heard of that! But I like stock flywheels anyway. I would torque them down as much as possible personally, like 70 ft/lbs or whatever I can do with just a ratchet, no breaker bar or torque wrench, and i would use the super lock tite (200ft/lbs) to be sure. Just what I would do if I couldnt figure it out otherwise (call email fidanza)
