Fidanza flywheel ring gear swap question
IntactTSI
Aug 13, 2004
Sanford, Maine
I recently got a 6 Bolt FWD fidanza flywheel in a good part-out deal. I have a 6-bolt AWD, does anyone know if the ring gear could be changed for the tooth count difference? Would it be worth it if so?
Thanks
You're best bet is call Fidanza and ask to speak with Wayne, he is the tech over there, if it can be done he is the man that can do it for you, cause they have to be heated and pressed on. Very cheap to install, he is actually doing mine for me right now.
Sorry, I didnt see the fwd part, Yea I would call them up anyways, but from my understanding I dont think a fwd flywheel will fit probably in an AWD setup, if it will, you may have to change some things around on it.
